4 WD to 2 WD???
Old Aug 29, 2018 | 01:24 PM
DL HOLLY's Avatar
DL HOLLY
Question 4 WD to 2 WD???
2002 Durango RT 5.9L 4-Spd. Automatic 46RE Transmission
My question is can I remove the front prop shaft, and both the left and right half shafts and convert this AWD to a 2WD RWD vechile?
The reason I ask this is that I have had the SUV for 6 years and almost 200k and have never been off road once. Also parts are starting to wear out and since I never use the FWD portion can it be disconnected or removed from the drive line?
Thanks for reading and or responding.
Dan
Old Aug 29, 2018 | 06:07 PM
JeeperDon's Avatar
JeeperDon
You're ignoring the obvious fix.... take it off-road a bit, easy trails. This is like owning a convertible, never putting the top down, just not right.
Old Aug 29, 2018 | 06:35 PM
Keep in mind, the nut/outer cv joint is what holds the front wheel bearings together.
Also, you would have to drive it in Part-Time 4x4, otherwise all your power would go the front driveshaft. (which isn't there.....)
Winter obviously isn't a problem for you.
Old Aug 29, 2018 | 11:38 PM
that_guy's Avatar
that_guy
You are always using the front section of the driveline since R/Ts are full time 4wd/awd. And your front wheels will fall off if you remove the cv axles.
Old Aug 30, 2018 | 07:19 AM
I say go for it. Be sure to video your first drive after you do...
Old Aug 30, 2018 | 08:03 AM
Pspklutch's Avatar
Pspklutch
This ^
And take some good hard corners if you get it going!
