4.7L: How hard is it to change valve seats?
Old Dec 2, 2018 | 10:00 PM
deanbw's Avatar
deanbw
Originally Posted by Rob94hawk
What's the adapter to thread into the spark plug hold for my compressor to keep the valves seated? Just in case I don't get the piston all the way up I want backup.
Is this the right one?
https://www.summitracing.com/parts/lil-19700/overview/
Does it matter if I have a small compressor? Do I need a specific PSI?
Also, can I use the cam bolt to turn over the engine & find TDC?
Thanks
yep, that should do the trick, no you don't need a big compressor, just don't try to use a 12 volt tire pump...... and last no, don't use the cam bolt, use the crank bolt only, you will not like what happens if you use the cam bolt.....snap.....
