Engine noise- 1999
My 99 Durango has been changing its tune as of late. Not sure how to describe it, but normally its a nice and quiet, normal Durango. Sometimes, usually for a day or two, it'll be loud, then for a few days its quiet again.
The sound is kind of a drier sound, like a loud fan. It struggles to hit the higher RPMs, usually capping about 2k, and accelerates a little slower. Mileage seems to be the same, if not its like 1 mpg lower in its loud state. However, nothing was out of the ordinary during my checkup (currently it has a small rear differential leak and a decent oil leak at the rear main seal). Id like to know what might cause it and, of course, if i need to get it looked at or fixed. It did it with a full tank and with an eighth of a tank, and speed doesnt seem to matter.
Tires are brand new, brakes are in good shape, all parts are stock and the vehicle has never been in an accident; has just under 165k miles on it.
1999 Dodge Durango
5.9 V8
4WD
1999 Dodge Durango
5.9 V8
4WD
Fan clutch failing? That would make some noise, but, while it may make the engine feel a bit sluggish, it wouldn't limit RPM like you describe. That sounds kinda like a cat that's clogging up.
