HELP!! The RWAL ??? CAB is making noise
Old Dec 9, 2005 | 03:29 AM
blackdodge's Avatar
blackdodge
Default HELP!! The RWAL ??? CAB is making noise
Ok. So the wife calls me today freaking out because the ABS & brake light are on. I know as a Dodge owner ... speed sensor. Just replaced that anyways. But the RWAL module next to the master cylinder is making a racket even when the ignition is off. A constant HUMMMMMM. Ok So I disconnect that now what? I am lost. I pulled the abs fuse and reconnected the power to the mod (just to make it stop making noise) and now I have no idea what to do? Is this the rear speed sensor? or a bad module? I just had the rear end replaced about 5 k miles ago did they miss something? What now. Is it safe to drive? No ABS in then rear?????? What????
Old Dec 9, 2005 | 10:43 PM
Steeltown67's Avatar
Steeltown67
Default RE: HELP!! The RWAL ??? CAB is making noise
had the same problem last year
had the ABS mod changed ($700 cdn)
all better now
Steeltown
