Removing Scratches from rear panels
Old Dec 14, 2018 | 12:51 PM
GreenBayGuru's Avatar
GreenBayGuru
Default Removing Scratches from rear panels
Hey all,
Just got me an 03 R/T and finally going over it with a fine tooth comb I've noticed that the cargo area side panels are scratched up pretty good, Was wondering if theirs anything that can fix this up a bit and take the scratches out?
Thanks
Old Dec 14, 2018 | 03:06 PM
JeeperDon's Avatar
JeeperDon
It's plastic, so not much can be done other than replace the panel. Mine are a bit scratched too.
Old Dec 14, 2018 | 05:55 PM
that_guy's Avatar
that_guy
I don't know that you can really fix the scratches, but if they're white from the plastic stretching you can probably go over it (carefully) with a heat gun and get it go back to the original color.
Old Dec 14, 2018 | 07:37 PM
Pspklutch's Avatar
Pspklutch
You'll never get it perfect again without replacing them. If they're gouged pretty bad sometimes really fine sandpaper can make them look a little better. Heat gun helps bring color back. Mine are scratched up real bad, but I use the back often for lumber and anything else I may need. Plus my interior wasn't in the best shape anyway when I bought it with 215,000 miles.
