Looking for part number
Hi all,
In the midst of rebuilding my 2000 Durango with the 4.7L engine, I see that the heater hose from the timing cover that transitions from rubber to metal has a crack. Does anyone have the part number of those hoses? I don't really want to use "Pick-N-Pull" hoses if I'm this deep into the project;
Thanks,
Steve
Thanks,
Steve
Hi all,
Thanks,
Steve
Thanks,
Steve
If you mean those below... When mine leaked, I bought a roll of heater hose from Advance. I cut off the metal collars and pushed on the new heater hose back to the tubing, securing with worm clamps. With the clamps on, they won't fit in the plastic bracket but you can just zip tie it on.
Strange I cannot find the whole tube online...looks like I will going with your suggestion thanks
Auto parts stores sell the 5/8 heater hose in like a 3 or 6 ft roll. It does not come with the molded bends of the OEM hose, so make sure you do not kink the new hose. https://shop.advanceautoparts.com/p/...58bg/5190010-P
Using a cutting wheel on an angle grinder, I cut off the outer metal collar, which serves as a hose clamp. It was replaced with a worm clamp, once I got the new hose on. I did not cut the tube inserted into the hose. Does that clarify for you?
I see that now...was hard to see on my phone. When I pulled mine off, there were "splits" in the hoses..might be why I kept loosing coolant and smelling it without being able to find it...thanks again for the clarification
