Front suspension
Old May 20, 2019 | 10:11 PM
Packers4life's Avatar
Packers4life
Default Front suspension
I replaced all my front end suspension components lower control arm,upper, and shocks and my front end goes all way down was wondering if anyone had a problem like this before or can give me a fix.
Old May 21, 2019 | 07:43 AM
What are you driving?
Old May 22, 2019 | 04:33 AM
Packers4life
2003 dodge durango
Old May 22, 2019 | 08:05 AM
JeeperDon's Avatar
JeeperDon
My first thought was, "I'm a Lions fan, you're on your own!", but.... I suspect you didn't install the torsion bars correctly.
Old May 26, 2019 | 08:33 AM
b1lk1's Avatar
b1lk1
Agreed, only logical guess I can think of as well.
Old May 27, 2019 | 04:51 AM
Packers4life
Whats the correct way to install them?
Old May 27, 2019 | 08:11 AM
JeeperDon's Avatar
JeeperDon
Turn the torsion bar adjuster clockwise to raise the vehicle. If it won't adjust enough, you likely will have to re-clock it one hex flat over to get in the right adj range. That would mean you may have clocked it wrong on the control arm end when you put that in.
Old May 28, 2019 | 04:14 PM
Packers4life
Okay thank you it is not adjusting correctly that sounds like it could be it
Old May 28, 2019 | 04:19 PM
Packers4life
This is first time i ever messed torsion bars on a car
