Transmission
Old May 23, 2019 | 09:20 PM
Paul95's Avatar
Paul95
Default Transmission
My transmission is out of my 2001 durango, my cousin called and said he has a transmission from a 1999 dakota 4x4, v8 engine like mine. Does anyone know if this transmission will fit my durango ??? Thank you
Old May 24, 2019 | 12:23 AM
sporta's Avatar
sporta
Would be helpful to know what engine is in your Durango and the Dakota. Are both 4wd? (I know the Dak is but is your Durango?)
Old May 24, 2019 | 05:47 AM
Paul95's Avatar
Paul95
Both are 4wd and my durango is a 5.9 liter and he called back and said the dakota is a 5.2
Old May 24, 2019 | 07:23 AM
Dakota is likely a 44RE, your Durango probably has the 46RE, it would work, but, it's a weaker trans. You would also need to change the electronics in the transmission, to match the year of your truck, things changed from 99 to 00. They aren't compatible.
