545RFE throwing DTC 0750 in limp mode
Hey y'all, i hope one you transmission guys , or someone who knows more than myself, can help shed some light... trk is 2003 rango 4x4.. 4.7.. w/ 545RFE.. ...put in drive, it seems to not fully engage..slipping.. but will move. Pull down to 2nd or 1st and its all there tho i dont know if its starting in low or not. Reverse is strong also. I plug in scanner, and it immediately says trans in limp mode, and throws DTC 0750.. any insight is most appreciated thanks
[QUOTE=Charles Fahlbusch;3446266]Hey y'all, i hope one you transmission guys , or someone who knows more than myself, can help shed some light... trk is 2003 rango 4x4.. 4.7.. w/ 545RFE.. ...put in drive, it seems to not fully engage..slipping.. but will move. Pull down to 2nd or 1st and& its all there tho i dont know if its starting in low or not. Reverse is strong also. I plug in scanner, and it immediately says trans in limp mode, and throws DTC 0750.. any insight is most appreciated the ů]
...UPDATE.. after dropping pans on both trans, and both seeming in great shape judging by the tell tales, i dropped both valve bodies and swapped shift solenoid pack from donor trans into the unit in the durango. Upon firing it back up, first thing i noticed, trans no longer in limp mode. Momentarily threw a line pressure code, then all clear. Truck runs and shifts like a champ
