1998 Dodge Durango 5.9l IAC Check Engine Light Issue
Old Sep 16, 2019 | 02:40 PM
sporta's Avatar
sporta
Default 1998 Dodge Durango 5.9l IAC Check Engine Light Issue
Hey all
Trying to help the roommate out with his new to him '98 Durango. When he got it, it was throwing the "P0505 Idle Air Ctrl Motor Circs". Previous owner claimed to replace the IAC valve but for sure did not remove the throttle body and clean it. Having a "spare" throttle body off the disaster that was the engine from my son's Durango, we cleaned the heck out of it and installed it on his '98. Basically we followed all the instructions that hydrashocker posed in the DIY section although to get into the nooks and crannies of the TB I used a couple of round nylon bristle brushes and then used air to make sure all debris had been removed. As it had been sitting for a while, the battery was toast. After using dad's 3500 Ram to jump it and make sure it ran, roommate went out and got a battery...Now it's exhibiting a somewhat rough idle (haven't seen it myself, but I theorize that its due to the stale gas) and it threw the P0505 again. I'm thinking it was a generic IAC valve that was used and not a Mopar branded one. Is there anything else that I am missing on the surface? Going to re-check the IAC connections and the valve...also going to check the idle...
Any suggestions would be appreciated...
Thanks in advance
Steve
Old Sep 16, 2019 | 07:32 PM
Usually, when I see the P0505 code, even after cleaning/replacing the IAC, that points to a bad driver in the PCM. With ignition on, (engine off.) test the four wires in the IAC connector, you should see 12 volts on two of them.
Old Sep 16, 2019 | 07:59 PM
sporta's Avatar
sporta
OK, if its a bad driver in the PCM, does it mean that the PCM can be swapped with one from the Junkyard if the numbers match or are we stuck with buying one off Ebay that is "flashed" to the VIN?
Thanks,
Steve
Old Sep 16, 2019 | 08:41 PM
Being a 98, and it will likely want to have the correct VIN flashed to it. I don't think it really matters where you get it from, any shop with a commercial-grade scanner should be able to flash the vin.
Old Sep 19, 2019 | 11:03 PM
that_guy's Avatar
that_guy
I bought a spare pcm from the junkyard just to have one a few years back. As long as it's not an alarm one it should work as is. Only thing that doesn't work for me with the spare one is the fog lights.
