99 Durango fuel pump issues
Old Oct 23, 2019 | 04:09 PM
Heinz Edgar Rose's Avatar
Heinz Edgar Rose
Default 99 Durango fuel pump issues
99 Durango 4x4 V8 fuel guage is showing empty.
About 3 wks ago, truck wouldnt start, replaced the fuel pump, still no start. Jumper the relay, pump is running, still no start, still reading empty. Can anyone help with this?
Old Oct 23, 2019 | 04:59 PM
Check the contacts on the connector for the fuel gauge. (at the pump)
What brand pump did you get?
Old Oct 23, 2019 | 06:20 PM
Heinz Edgar Rose
Default Oem
I bought an inexpensive OEM from Rock Auto, but I cant remember the brand right now. Its working. Im having some other issues with the fuel system too, besides the gauge.
I have a jumper on the relay to work the pump.
Kinda lost on this one.
My next step is to try to trace the gauge problem from the gauge/fuse.
I read that theres about a 100 different things that could be causing a No Bus code on the dash that could affect the pump as well
Old Oct 24, 2019 | 07:02 AM
That's unfortunately true. On yours, EVERYTHING goes thru the PCM, so far as the gauges are concerned. Including the gas gauge. So, the No Bus error and no working gauges go hand in hand. *usally* the no bus is cause by some failure in the 5 volt circuit. It supplies signal to all the various sensors. Have a service manual for troubleshooting that is pretty much going to be a requirement.
Old Oct 24, 2019 | 08:14 AM
Heinz Edgar Rose
Have any suggestions for which service manual to get? Havent found any Haynes for my truck in my area
Old Oct 24, 2019 | 06:35 PM
Don't bother with Haynes, or Chiltons. They are too generic. You want the REAL factory service manual. You can usually find them in digital, or DVD formats, for pretty cheap on ebay, or, you can spring the big bucks for the paper copies. I think Bishko was the publisher for the factory manuals. (worst case, you can go their site, and likely find them in various formats as well.)
Old Oct 28, 2019 | 07:18 PM
that_guy's Avatar
that_guy
There's a link to pdfs of the factory manuals in the diy section of this forum.
Old Nov 4, 2019 | 09:15 AM
Heinz Edgar Rose
Question, would I be able to smell fuel from the exhaust if the pump was working but there was no spark? And if the new pump is creating enough pressure, could that be an electrical problem, a pump problem, a fuel line problem, or a combination of the above?
Thanks
Old Nov 4, 2019 | 05:01 PM
that_guy's Avatar
that_guy
To check if you have pressure at the rails, get/borrow a fuel pressure test gauge and hook it to the test port.
If you want to check for spark, pull a plug, ground the body against the block or something (don't hold it with your hand.), and see if it sparks.
