Lower control arm torsion bar
Old Oct 30, 2019 | 01:35 PM
dontilgon's Avatar
dontilgon
Default Lower control arm torsion bar
So I was being joe mechanic removed the up and lower control arm and axle to install new. Started to replace control and realized I have no clue how to set the torsion bar . Did some reading and didn’t mark the anchor bolt. Any advise would help considering Im stuck
Old Oct 30, 2019 | 07:08 PM
tshephard's Avatar
tshephard
If you only did one side, then just level it.
The procedure is crazy specific, measuring unmarked part centers difference to floor, to 100ths.
Adjust, jounce - girlfriend on bumper a couple of times - adjust again.
Level to other side will be fine.
Old Oct 30, 2019 | 07:59 PM
dontilgon's Avatar
dontilgon
Thanks for the reply but I’m not sure how the lca should sit before I start screw in the Anchor
