Power Steering Pressure Hose
Old May 9, 2020 | 09:49 PM
Zane007's Avatar
Zane007
Exclamation Power Steering Pressure Hose
I have a 4.7L 2003 Durango. Recently the high pressure power steering hose has started spraying fluid everywhere. I can't seem to remove the hose where it connects to the pump. I have removed the battery, serpentine belt, and splash guard and am just able to fit a small wrench on the hose but I don't have enough leverage. Any other ideas would be much appreciated.
Old May 10, 2020 | 07:31 AM
May have to remove the pump.
Old May 10, 2020 | 08:20 AM
Put the wrench on the fitting, and use a drift and hammer to break it loose. Once its loose, you can probably just use your fingers.
Old May 10, 2020 | 09:11 PM
Zane007's Avatar
Zane007
I have heard that people were able to replace this hose without taking the pump off. Here are some pictures of the fitting.
Old May 10, 2020 | 09:20 PM
Crowfoot wrench.
Old May 10, 2020 | 10:44 PM
Zane007's Avatar
Zane007
I had no clue those existed but it looks like it will work perfectly. I'm going to pick up a set tomorrow.
