A/C blows hot out of the front but cold out of the rear.
Old Jul 29, 2020 | 07:28 AM
Aesocbar33's Avatar
Aesocbar33
Default A/C blows hot out of the front but cold out of the rear.
I have a 1999 Durango 5.9 4x4 and the AC has been fine up to a couple weeks ago when it stopped blowing cold air out of the front and only cold out of the rear. Freon levels are good. I checked the pressure and it’s also good. Vacuum is good. I drained and refilled AC and still nothing. One thing I did notice is the evaporator lines are not getting cold. Any ideas of what the problem could be?
Old Jul 29, 2020 | 07:53 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the drier/filter or expansion valve for the front (i believe front and rear have separate units for these, but i can be 100% certain).
the fact that the back works and the front doesnt tells you that the charge is good (or at least acceptable) and that the compressor is working fine, its something specific to the front system. Since the lines are not getting cold i would be looking at the expansion valve first then the drier for a clog.
Old Jul 29, 2020 | 08:08 AM
Aesocbar33's Avatar
Aesocbar33
Thanks! I’ll definitely check both of those out. I’m hoping it’s something cheap like a valve.
