46RE interchange
Old Aug 2, 2020 | 05:05 AM
Mile High Jeeb's Avatar
Mile High Jeeb
Default 46RE interchange
What all will have to be done to make a 98-00 46RE work in an 01 R/T AWD beside swapping the transfer case? I ask because the 4x4 selector is an electric switch in the 01+ and a manual lever in the previous '00 and under. Thanks
Old Aug 2, 2020 | 07:31 AM
98 and 99 used different electronics than the 00-01, so, those will need to change. Retainer for the governor pressure stuff is different as well. Aside from that, if both transmissions are from 4x4s, should be a direct swap.
Old Aug 2, 2020 | 10:52 AM
Mile High Jeeb
Are those internal?
Old Aug 3, 2020 | 08:30 AM
Yep. Just gotta drop the trans pan.
