Engine Noise
Old Oct 14, 2020 | 06:49 PM
RLewis's Avatar
RLewis
Default Engine Noise
I appreciate any help with my 03 Durango 4.7. The noise started about 19 months ago/10k miles ago. My mechanic said it was the A/C compressor and when it got too bad;loud I would need to replace. A few weeks ago, I switched to a synthetic oil and the noise appeared to get louder. Removing the drive belt did not silence the noise, so I guess it is in the engine.
Below is a link to video of the noise. 130k miles. Head gasket and timing chains/guides/tensioners were replaced 45k miles ago. The "speed" of the noise increases with RPMs. The noise is persistent at startup through operating temp and beyond -- does not stop. Using a mechanic stethoscope, it appears to be loudest at the front passenger side of the engine around the A/C compressor. Any ideas of what the noise could be? Thank you in advance.
Old Oct 14, 2020 | 08:15 PM
Dodgevity's Avatar
Dodgevity
Take off the serpentine belt and run it for a quick minute. If you still hear it, it's not the compressor or anything in the belt path.
Old Oct 14, 2020 | 08:19 PM
RLewis's Avatar
RLewis
I appreciate the response. Yes, I removed the serpentine belt and the noise is still there.
Old Oct 14, 2020 | 09:06 PM
Dodgevity's Avatar
Dodgevity
Sorry, I missed that part in your initial post. It sounds like a valve issue. Are you getting a check engine light? If so what are the codes? You may need to pull the valve covers, at least the one closest to the sound.
Old Oct 14, 2020 | 09:56 PM
RLewis's Avatar
RLewis
Great suggestion. I will do that. There have been no error codes. Are you thinking a valve is stuck open (eg dropped seat or bad lifter)? Also, here is another video taken while I open the throttle with the mic near the oil fill. Thanks!
Old Oct 15, 2020 | 07:54 AM
Dodgevity's Avatar
Dodgevity
Maybe. Being that there are no codes, it's hard to tell what is going on there. I recently replaced all my lifters due one seizing and ejecting a rocker, but it generated a code. Did the noise start suddenly, or develop over time? How is the oil pressure and has the engine been run low on oil?
Old Oct 15, 2020 | 09:15 AM
RLewis's Avatar
RLewis
The noise did develop over time. My mechanic incorrectly believe it was the A/C compressor 10k miles ago and it is louder now. I think the increase in loudness began after switching to synthetic, but that might be my imagination. There have been no warning lights about oil pressure, but I just ordered a gauge and it will be here in time for the weekend. Following the head gasket repair 5 years ago, there was a valve cover leak. For this is reason, it is possibly that oil was low at some point. Thanks.
Old Oct 26, 2020 | 01:10 PM
sporta's Avatar
sporta
https://vimeo.com/468247053
OK, my $0.02 here....it sounds similar to my 2000 Durango with the 4.7L V-8 when the passenger side timing chain tensioner was failing. It might have already damaged the plastic timing chain guide...that could be the clicking sound. When I did mine, I totally screwed up the first time and (because it was in the timing chain kit) installed a metal backing plate behind the passenger side tensioner. Check for posts under my user name....should be a pic of what I am talking about...if you need me to I think I still have them on my PC...
Best of luck.
Steve
Old Oct 26, 2020 | 01:13 PM
sporta's Avatar
sporta
https://vimeo.com/468381297
From experience, (dropped valve seat on cylinder #2 on my 2000 Durango and #8 on my 2001 Durango) it would not be running that "good" if at all....also should be tripping a check engine light showing a misfire. Hope this helps
Steve
Old Oct 28, 2020 | 11:41 PM
RLewis's Avatar
RLewis
Thanks for the response. I pulled the valve cover and it looked normal. The right secondary timing chain could be a little loose, but I am not sure. It is my understanding that the tensioners rely on oil pressure and when I inspected there was no oil pressure. Another mechanic friend I showed it to also believed it was the timing chain. He listened to the noise and recommended trying a Lucas Oil additive. I tried the additive and it didn’t work. Is this something I can live with for a while (just noise) or should I replace soon?
Steve
