Compatible transmissions for the 4.7 to replace the 45 rfe
Old Nov 4, 2020 | 12:01 AM
Hippiezombiecow's Avatar
Hippiezombiecow
Default Compatible transmissions for the 4.7 to replace the 45 rfe
I'm interested in knowing what transmissions will bolt up to the 4.7 and work, or if there are any. I read about the 45 rfe to the 545 rfe being a simple tcm swap, but I'm hoping I can find a torque-ier transmission and more than likely a better transfer case, thank you for the help
Old Nov 8, 2020 | 02:17 PM
that_guy's Avatar
that_guy
There might be others like the 65rfe that bolt up but good luck getting the electronics to work. Get a 45rfe built and call it good. And yes the 45rfe and 545rfe are identical, it's just programming and how it utilizes all 6 (yep, it's really a 6 speed, but doesn't use them all sequentially) of it's gears.
Old Nov 10, 2020 | 07:31 AM
Dodgevity's Avatar
Dodgevity
Far as I know and have read, the 545RFE is a pretty strong unit. I've got 317K on mine and never had a peep out of it. Still shifts like it's reading my mind. It probably helps that I've got the tow pkg which includes the heavy duty cooling (external cooler) and I installed a drain plug in the pan, so I drain it every 25K or so.
Old Nov 11, 2020 | 08:27 PM
Russell072009's Avatar
Russell072009
170k on mine but the 3 times I have had the pan off there was a LOT of material in the bottom of the pan. Still shifts properly but I hesitate to tow with it.
