freshly rebuilt 46re tranny, no OD
98 Durango 360 4x4 158,208 with 12,000 mile warranty freshly rebuilt 46re training with new torque converter installed it filled it up with transmission fluid connected all the wiring correctly and looked at it for frayed wires,
Took it for a test drive seemed fine until hit highway speeds at 60 MPH I was at 3000 RPM and it didn't make a difference in rpm whether you hit the overdrive button or not.
Plugged scanner into the vehicle after test drive and all these codes popped up I'm calling the shop tomorrow figured I would see if anyone could help out.
I'll be asking what they all replace majorly when they re built the transmission,
Po753 shift solenoid
Po713 tranny temp sensor a
Po300 random misfire
Po302 cylinder 2 mis
Po183 oxygen senors high
Po711 tranny temp sensor senors a
P1763 no dtc
Po308 cylinder 8 misfire
Po141 oxygen senors
P1763 no dtc
Po141 oxygen senors
P0753: The PCM is commanding Overdrive, but, not seeing the RPM drop. Bad solenoid, or, wiring issue.
P0713: Trans temp sensor. Either a bad/wrong sensor, or wiring issue. In this case, the PCM sees a high output signal, which it interprets as high trans temp. That will also disable O/D. Is the trans temp lite in the dash coming on?
The transmission temp light comes on then goes off after started I call the shop and explain it to them they said bring it in and most likely it's the cable on side of transmission that needs adjusting, could cause all type of problem,
After work imma look at the wiring and solenoids, and I'll be taking it in Monday. But I do appreciate the help, made me understand it better
