Catalytic removal
Old Feb 25, 2021 | 12:17 AM
johnnyrango1999's Avatar
johnnyrango1999
Default Catalytic removal
I have a 99 Durango with an exhaust problem, my codes are telling me voltage issue with 02 sensors and i just replaced them both. Im going to check the connections tomorrow to make sure they are clean and secure but im pessimistic of this because i need to replace the actual muffler since it's got a hole in it and I'm wondering if i remove the cat also after replacing the muffler if that will cause more problems if i leave it out?
Old Feb 25, 2021 | 07:37 AM
Other than failing inspections (if you have them) and a constant check engine light, it won't cause any problems.
Old Feb 25, 2021 | 09:43 AM
PCM may or may not whine about cat efficiency...... some are more sensitive to it than others.
Old Feb 27, 2021 | 08:33 PM
volaredon's Avatar
volaredon
my 96 Dakota didn't care... but my damn 01 Durango, well, it went a whole 138 miles before it threw a fit and lit the check engine light, I had to put a new cat onto that one..... I wasn't happy about that.
Old Mar 2, 2021 | 11:51 AM
Kensai's Avatar
Kensai
I had mine replaced at 200k, doubt the cat was still working efficiently. So bought a high flo low restriction cat. made a noticeable difference in acceleration afterwards...
Old May 10, 2021 | 11:17 PM
Hippiezombiecow's Avatar
Hippiezombiecow
My 2000 durango with the 4.7 hasn't had any issues, I also don't have the second one hooked up to the exhaust, im not sure how much that affects it, It does run pretty lean.
