ECM Codes
Old May 12, 2021 | 12:40 PM
davidlwoolard's Avatar
davidlwoolard
Default ECM Codes
2000 Dodge Durango 5.9L 4WD.
I have the following ECM Codes and trying to clear:
P0443
P0753
P1740
P1765
Please can someone tell me what these codes really mean and part numbers?
I look forward to all responses.
Thank you very much
David
Old May 12, 2021 | 02:09 PM
You can look up your codes here.
First on is evap purge control issues. Might be bad wiring, might be bad valve....
Last three are all trans related. Last one is for trans relay control circuit fault... which would prevent pretty much everything else in the trans from working right.....
