2 power windows dropped just hours apart
Dear Forum Mechanics - I was just saying this very day how lucky I have been not to have any car repairs.
Then leaving the grocery , getting back into my car , I see the front passenger window down. I did not leave it down.
The control does not raise it there is noise but no lift.
Then I get home and put a tarp over the open window ( we may have rain).
I opened the back passenger side door to tuck an edge of the tarp in the door. When I closed the door ( my drive way is an incline)
So I pushed the door to close it. As it shut , the window dropped down ! So now that's two windows down in the same afternoon!!!
I think the failure has to do with the 99 degree heat the last two days.
I'm guessing some plastic part or rubber part melted;? cracked? --obviously some part failed .
I've talked to three shops they all want hundreds of dollars and they want to replace the whole
window regulator with the motor. I hear that window regulators fail a lot.
That manufacturer has a nerve making an assembly that cant's be fixed, except by replacing the whole thing.
The weakest part ( their bread and butter) fails and they get another order for the entire assembly!!
I'd like your advice.
Recently I was given very clear advice about the wet on my driver's side floor.(I have a loose window gasket that allowed rain in .)
I know this time there is obvious repair needed.
I'm in Austin TX, I would also appreciate recommendation for a economic mechanic.
I'm 71, unemployed and both my tenants are moving, so no income in July and just my Soc sec.
Sincerely,
Resa
Durango 2003
Sincerely,
Resa
Durango 2003
Last edited by willowbee; Jun 15, 2021 at 06:16 PM. Reason: I want to add my veh type and age
