Motor Swap
Old Sep 3, 2021 | 07:08 AM
kytlnpapa817's Avatar
kytlnpapa817
Default Motor Swap
Hello, first I hope I'm doing this new thread posting right? OK my Question to you the pros is I have 2003 Dodge Durango 4.7 V8 can I swap it out with 2004 Dodge Durango 4.7 V8 without a lot of headaches? I'm just learning about mechanics and I would be grateful for any advice. Thank you for ur time and patience, much appreciated
Old Sep 3, 2021 | 07:35 AM
Dodgevity's Avatar
Dodgevity
Yes, those should be identical engines, so any headaches should not be related to compatibility.
Old Sep 3, 2021 | 03:51 PM
kytlnpapa817
Default Motor swap
Thank you for responding and the information you provided, I have found the 2004 V8 replacement motor still in the vehicle so I can start it and hear it run, do you recommend changing out any specific parts or checking certain ones before installation into 2003 vehicle besides of course new fluids? Thank you again for ur help
Old Sep 4, 2021 | 06:16 AM
tshephard's Avatar
tshephard
Somewhere (sometime?) there is a difference in flywheel teeth flywheel sensor, something like that - affects PCM count.
Old Sep 4, 2021 | 07:40 AM
kytlnpapa817
Default Motor swap
Thanks for the information you provided to me, I will definitely look into that. Thanks for the heads up and for ur time to respond to my question
