battery 12V power outlet
Old Nov 8, 2021 | 12:43 PM
George Genovezos's Avatar
George Genovezos
Default battery 12V power outlet
Hi all,
Is there any way to have the power outlets always on? currently when they key is on the outlets have power, when off none. I've seen some newer Dodge trucks have a fuse you can move from alternator to battery and that powers the outlet. Anything similar for gen 1?
Old Nov 8, 2021 | 03:10 PM
Have you looked to see?
Old Nov 8, 2021 | 05:14 PM
George Genovezos
i have. didn't see anything
Old Nov 8, 2021 | 07:08 PM
Usually, at least one of them will be constant power......
Old Nov 10, 2021 | 04:18 PM
JeeperDon's Avatar
JeeperDon
My 2001 R/T has three outlets, under the dash, in the console, and in the rear cargo area. All are hot with the key off. What's hot or not must be model/year related.
Old Nov 10, 2021 | 04:35 PM
George Genovezos
Interesting.
I have power for the cigar lighter only when key is on. The one in dash has no power. EVER
Old Nov 10, 2021 | 07:01 PM
Dodgevity's Avatar
Dodgevity
The map lights work with key off so that's one source you can tap. Also there should be a memory wire going to the radio. Probe them with key off.
