Camshaft location sensor 94 ram for a 99 durango
Old Feb 5, 2022 | 03:50 PM
Marieg44's Avatar
Marieg44
Default Camshaft location sensor 94 ram for a 99 durango
I have a 1999DodgeDurango 5.9L V8 4x4 and I went to a friends house and my truck ran just fine over there. I was there for about 4-5 hours and the temp dropped to about 4 degrees Fahrenheit. I went out to start my Durango to go home and she would crank up but wouldn't actually start. There's gas in her, checked the fuses all good.
ok the question I have is I have a 1999Dodge Ram 1500 2 wheel drive, 5 speed stick shift. Whenever I looked up the issues my durango was doing it said the CamshaftPositionSensor, under the distributor cap. Now on both trucks the parts look the same but my 1999 dodgecamshaftpositionsensor OEM part number is MOP-68569185AA and the signal is 5v input/output and when tested it's only outputting signal 3.7v. My 1994 Ram OEM part number MOP-68080819AC and signal is 8v input and only 5v output. Can I use the sensor off my ram and put it on my durango until I can get the part I need?? I have no other transportation and can't get a job without a vehicle.
I am also wondering if someone could possibly tell me how to check if it is my camshaft location sensor?? friend tested it with a multi meter and said that's what it is?? Sorry a lot of jumbled info I'm just trying to get it all in here.
Thank you in advanced for everyone's help.
Old Feb 5, 2022 | 06:22 PM
Part numbers are different, so, I wouldn't expect it to work... but, might be worth a shot.
