Heads overmilled 4.7?
Old Apr 24, 2022 | 11:39 PM
Hippiezombiecow's Avatar
Hippiezombiecow
Default Heads overmilled 4.7?
I recently rebuilt the top end of my 2000 dodge durango. I sent the cylinder heads to a fairly high rated machine shop in spokane. I've read that resurfacing the heads can cause some kind of timing issues, and I was hoping someone could go into more detail about it. My D sputters and spits on start up, and after choking for a moment, idles fine, but as soon as you press on the gas, she chokes again and dies.Anything helps, thank you for your time.
Old Apr 25, 2022 | 08:42 AM
Surfacing the heads will move the cam gears lower, but, the chain is still the same length.... so, timing will be a bit 'off'. However, the amount taken off the heads is measured in thousandths of an inch, so, I don't really see that as having that much of an impact on how the engine should run. I would be tempted to re-verify the timing chains were properly installed, and the assorted timing marks all line up as they should. If that checks out, have a look at fuel pressure, and what your sensors are telling the PCM.
