Need help 2003 durango
Old Sep 13, 2022 | 04:56 PM
The only really complicated part is getting that mondo spring out of the o/d unit. Need a press for that. (it's like an 800 pound/inch spring.... you ain't compressing that by hand, and the consequences of some makeshift method failing would be.... dire..... to say the least. ) One of your local shops would likely take it out/install it for you, if you smile nice. (and throw money at them.....) Or, buy a cheap harbor fright press. I got mine used for 50 bucks.....
I would still go with some upgraded clutches.
Other broken parts? Good question. You might get lucky, then again, you might not..... if you have something else to drive while the truck is down, then it becomes a non-issue. If you have to get it done in a weekend, because it's all you have to drive.... makes life much more interesting.
Old Sep 13, 2022 | 10:41 PM
jmn1960's Avatar
jmn1960
Thanks for the info, I have a shop to look at it on Thursday to see if it is something that i missed (i am not a tranny guy), all he does is torque conv. & trans. and think it is something little, i hope so, we will see.
Once Again
Thank You All for the help & info.
Will post an update either way.
Old Sep 19, 2022 | 08:15 PM
jmn1960's Avatar
jmn1960
Well had a tranny guy pull the pan and look around, Broken servo on the reverse adjustment side, had a hole in the bottom of the servo where the lever pushes on it, common fail he says, also that spring under the 5 bolt plate was broken,(i thought it was a 2 piece like a valve spring) but i was wrong. oh well we got reverse and all others working well. $350 thought that was fair so i gave him a $50 tip.
Thanks to all for the help and info, You All ROCK
MIKEY
Old Oct 6, 2022 | 04:10 AM
Awerss's Avatar
Awerss
replace shift solenoid
Old Oct 6, 2022 | 04:11 AM
Awerss's Avatar
Awerss
Old Oct 7, 2022 | 09:21 AM
jmn1960's Avatar
jmn1960
why replace the solenoid?
Old Oct 7, 2022 | 10:57 AM
If it ain't broke, don't fix it.
Old Oct 7, 2022 | 11:30 AM
Dodgevity's Avatar
Dodgevity
Forum motto!!!
