Cat delete, straight pipe.
Old Mar 1, 2023 | 03:11 PM
Free1990's Avatar
Free1990
Default Cat delete, straight pipe.
I’ve deleted the cat, now running straight pipe 3” exhaust. Check engine light is on now, I scanned the check engine light, the problem is coming up for the O2 sensor, why is this happening, and how can I fix the issue.
1999 dodge Durango 318 5.2
Old Mar 1, 2023 | 03:12 PM
Which O2 sensor? You have several. (at least two.) Wasn't the front O2 actually screwed into the cat??
Old Mar 1, 2023 | 03:22 PM
Free1990's Avatar
Free1990
i scanned it send it said both have a short.
Old Mar 1, 2023 | 03:25 PM
Unplug 'em, start the engine. You should see 5 volts on one pin, and 12 volts on another, other two will be grounds. (test on the harness side with em disconnected.) See what you get there.
Old Mar 1, 2023 | 03:32 PM
Free1990's Avatar
Free1990
Maybe it needs a tune up? Could that be the issue?
Old Mar 1, 2023 | 03:36 PM
Depends on what the codes are. Given they are talking about a short, tune up likely won't do a thing for those... but, the engine may run better anyway.
Old Mar 1, 2023 | 03:39 PM
Free1990's Avatar
Free1990
Ok so back to the o2 sensor, I’ll try unplugging and doing what you recommended.if all else fails , willI have to put the cat back on?
Old Mar 1, 2023 | 07:30 PM
Probably not. I believe you have an electrical problem. If you can solve that, then the lack of a cat may (or may not...) give you a catalyst efficiency code, but, those are easy to work around.
Old Mar 2, 2023 | 08:44 AM
Free1990's Avatar
Free1990
do you have any idea of what can cause a short to the o2 sensors?
Old Mar 2, 2023 | 09:14 AM
It's exactly that. A short. Could be a bad sensor, pinched wires, melted connectors, or any of a number of other things.
