Not again! This will take more than an average mechanic to fix
Old Mar 28, 2023 | 08:43 PM
theresajengle's Avatar
theresajengle
Default Not again! This will take more than an average mechanic to fix
Is there anyone out there that can? A few months back, I posted “I have a
2000 Dodge Durango and the driver's door had frozen shut HOW DO I
TURN OFF THE ANTI-THEFT THING?” I poured hot water on the door then,
as I got it open, the alarm went off. I was unable to figure out how to turn it
off. Even after doing a long list of what others had instructed for me to do,
nothing fixed it. It wasn’t until a neighbor had found the switch/connector
inside the door that disarms the alarm, it has a green/orange wire and a
black wire. That connects to the back of the lock, where the key goes. He
disconnected the plug from behind the keylock, cut the plug off and basically
hotwired it by connecting the 2 wires together. that fixed it. So, now, at the
present time, the alarm is going off again, but under different circumstances.
It all started when I was driving down the road hit a bump and the rear 3rd
break light/molding had fallen, dropped down about halfway. I drove home
and decided to fix it the next time I drive it. So, a few days later, I went
directly to the trunk lid, knowing that it was unlocked, I opened the lid, and
the alarm went off, again. I have been trying to fix it for more than a month.
The last thing that I tried was to do the same thing to the trunk lid
switch/connector wire thing as was done to the driver's door. That didn’t fix it.
Im out of ideas, Isnt there anyway that I can just turn that doggone "antitheft"
thing off, forever? A way to disengage it, hotwire it, disconnect it, cut some
wires, jerry rig it? blow it up? Kill it? That would be ideal for me..I hate it! I
don’t want it or need it. I haven't found a mechanic that can figure it out. This
is without a doubt a problem that will take a very experienced “technician” to
fix. Not just a mechanic. I am a single 59-year-old female on ssi and can't
afford what I fear that it would cost to have it fixed. I cannot express how
important it is for me to fix this, I have been stranded for a long time, I have
some money but not enough to have it towed to the dodge dealers for them
to fix. No doubt it would probably cost more than the car itself. At this point,
Im desperate for a solution that is within my means. Thank you to anyone
who will try.
Old May 26, 2023 | 04:21 PM
theresajengle
FINALLY, I BY MYSELF FIXED MY CAR!!! with the help of people answering my post. I first went to some junk yards & found the wires that had been "hot-wired/destroyed" and replaced them.After that, I referred back to all of the responses that I collected from people. I editing the info, making it into printable form & as a list, in the order of priority. The first was, "RECHECK THE WIRES THAT WERE WORKED ON BEFORE. HITTING THE BUMP MAY JARRED THEM LOOSE""CHECK THE GROUND CONNECTIONS ON THE BATTERY &ANY OTHER GROUND POINTS ON THE CAR.""MAKE SURE ALL GROUND CONNECTIONS ARE CLEAN & TIGHT." So, after I did that, the car started! Took less than 15 minutes!
It had been down since before Xmas. It took me a lot of time to methodically go through all the steps I thought that I needed to fix my car on my own, having limited funds. I want to thank you all for helping me.. without your help I would not have been able to fix it myself!! THANK YOU!!
Old May 26, 2023 | 05:01 PM
Congrats!
This is what forums are for.
Old May 26, 2023 | 06:47 PM
theresajengle
Smile
Originally Posted by heyyou
congrats!
This is what forums are for. :d
thanx so much!!
