Timing chain cover and water pump installation.
Old Sep 28, 2023 | 08:54 PM
Ink stain's Avatar
Ink stain
Default Timing chain cover and water pump installation.
Hello forum. I have a 1999 Durango, 4 wheel drive, and 5.2 engine. I'm trying to find the torque Pattern/ sequence for the timing chain cover and water pump bolts. I recently replaced the water pump due to bad bearings. I pressure tested the cooling system and went over the pump and chain cover areas with a spray bottle with soapy water. It was leaking between the chain cover and engine block where the 4 long water pump bolts are located. I removed the chain cover, cleaned the chain cover and block . My after market manual gives the torques but not the torque Pattern. Does anyone have that? Thanks
Old Sep 29, 2023 | 07:18 AM
Just do 'em like lug nuts. Crisscross pattern, and tighten in stages.
Old Sep 29, 2023 | 09:11 PM
ol' grouch's Avatar
ol' grouch
...and put some coolant tolerant RTV on the threads of the long bolts that go into the water jacket.
Old Sep 30, 2023 | 08:20 AM
Yes. This.
