brakes help?
Old Apr 28, 2004 | 11:37 PM
mike 77's Avatar
mike 77
Default brakes help?
I am getting ready to change front brake pads and rotors, and haven't delt with ABS much. Is there anything specal I need too do with the ABS. Any help would be good, and if someone could run me through changing the brakes and rotors would be great[ul]
Old Apr 29, 2004 | 01:49 AM
dodgemech's Avatar
dodgemech
Default RE: brakes help?
Very easy---word of caution, be very careful starting the bolts that attach the caliper to the spindle, they are tricky to get in straight and if you cross thread them it will need to be Heli-coiled. You won't be happy. You will need a 7mm hex wrench to get them apart.
Old Jul 14, 2004 | 08:04 PM
robust57's Avatar
robust57
I am one of those unhappy people, or a dumba$$. Can you tell me where to get a heli coil set specifically for the caliper to steering knuckle?
