Sxt or sport
Old May 30, 2024 | 12:13 PM
Lindalou272's Avatar
Lindalou272
Default Sxt or sport
Sxt or sport
I need a gear shift cable and a shifter with the shift mechanism thing and my vehicle says sxt but when it comes up using vin it sometimes says sport depending on where I look for parts. Is there a difference I'm AG at the end AE or Al I have already bought one cable amd it broke again. My shifter has a connection througj what I believe is the neutral safety bit I saw one at the junkyard that attached rigjt on a ripple on the mechanism and not behind it where it keeps getting jammed. Can I take it out of the one in the junkyard and use it or does it have to e like the o e that I sorts I to tje black switch. Green coil or red.
Old May 30, 2024 | 02:32 PM
Last two numbers are just the revision number. (or manufacture date, depending on what site you go to.) If the numbers are the same, it's the right part.
I would be real curious why they keep breaking though....
