'99 Durango reverse light problem
Well, the reverse light is "off", see, when you put your car in reverse, the backup lights turns on right, well, I guess the switch on my truck is off, the lights turn on right at the bump between the P(parking) and R(reverse) position, and not at the R, the way It is supposed to, anyone knows how to fix this problem or adjust this?
Sounds like you have something stuck inside the switch. Pull the switch out and clean it or replace the switch. Also look inside the hole and see if there is anything inside that could be blocking it.
ORIGINAL: hydrashocker
