2000 dodge durango
Old Jul 8, 2024 | 03:44 PM
sk3tchysam's Avatar
sk3tchysam
Default 2000 dodge durango
I have a 2000 Durango 5.9 slt the last codes it had come up were p1765 and p0753 and was wondering if it would be easier to fix myself or to take to a shop instead
Old Jul 8, 2024 | 06:48 PM
Make sure your trans is getting 12 volts.... if the solenoids don't have power, they won't work.....
Old Jul 9, 2024 | 02:53 PM
sk3tchysam's Avatar
sk3tchysam
what would i need for this??? would something need to be replaced?
Old Jul 9, 2024 | 04:10 PM
Need to verify the problem before you start thinking about spending money. With engine running, you should see 12 volts down at the trans. Which pin it is varies by year/engine/trans..... PCM controls a relay in the power distribution center to supply that 12 volts. Of course, it could be as simple as blown fuse......
Old Jul 14, 2024 | 11:01 PM
sk3tchysam's Avatar
sk3tchysam
I have a 2000 Durango with a 5.9L and I believe its the 46re
