Newbie question with hard start
Old Jul 24, 2024 | 04:31 PM
Tonymwc's Avatar
Tonymwc
Default Newbie question with hard start
Ok it’s 2000 Durango SLT 4.7,
try to start it and it will crank for about 3 to 4 seconds and slowly start to fire, but if you stop and turn the key again it fires right up, that’s pretty consistent, won’t start the first time unless you crank for awhile but if you turn it over again starts right up. If you hold it till it starts it kinda feels like it chugs a little bit then idles fine. Any help? Plugs are good cleaned throttle body clean air filter.
Old Jul 24, 2024 | 09:34 PM
Try cycling the key on-off, on-start.... Listen for the fuel pump to run the first cycle, off when the pump stops, then on, pause, crank. See if it starts right up then.
Old Jul 25, 2024 | 11:41 AM
Tonymwc's Avatar
Tonymwc
Actually did that this morning and fired right up with a tad of hesitation
Old Jul 25, 2024 | 08:30 PM
Bad check valve in the fuel pump; More annoying than anything else. Just cycle the key a time or two before the first cold start of the day.... Otherwise, its replace the entire fuel pump module.
Old Aug 14, 2024 | 12:18 PM
Tonymwc's Avatar
Tonymwc
Exactly right! New pump and starts right up! Thanks @ heyyou
