Transmission codes
Old Aug 6, 2024 | 08:44 PM
George Genovezos's Avatar
George Genovezos
Default Transmission codes
Hi all,
I have 4 codes that just popped up as I was driving. P0743, 711,712 and 713. I'm guessing 711-713 are a bed temp sensor. what about 743?
Thanks!
Old Aug 6, 2024 | 09:04 PM
Check the 8 pin connector down at the trans. It plugs straight down into the top of the valve body. The wires like to pull out, and then short together, and you get some odd behavior.
Old Aug 7, 2024 | 07:34 PM
George Genovezos
Yup that's thatwhats it called? Or pn? Do i inpin and repin or do I splice the wires?
Old Aug 7, 2024 | 08:10 PM
I think your local neighborhood parts store should have a pigtail hanging on a peg somewhere. Just splice it in. Make sure its part of the problem first though.
Old Aug 7, 2024 | 10:55 PM
George Genovezos
I hear you man but how do you know for sure it's the connector? what am I looking for apart from the connector looking bad?
Old Aug 8, 2024 | 05:32 PM
Bare copper on the wires at the connector. Seems to be at least fairly common.
