New, Former Lurker on the Forums
Old Apr 21, 2025 | 03:15 PM
Kyvan's Avatar
Kyvan
I can't really tell how bad the damage is to the frame, which would be the final nail in the coffin, so to speak. I would be 100% willing to get a new {"new"} engine and transmission. The issue is, I was told by the trusted mechanic who works on it, I would need an engine/transmission that is compatible with the 4x4 suspension, even though it doesn't have 4x4 anymore.
Old Apr 21, 2025 | 03:19 PM
Kyvan's Avatar
Kyvan
I will be on the lookout for another model around the same years. We will see how much a Salvage Yard would want for it. I have photos of some of the damage, but they won't upload. Would my engine and transmission work like that when I transfer to another vehicle? With the 4x4 issue I was told about, both parts may not work in a normal 2wd Durango. From what I understood from the conversation.
Old Apr 21, 2025 | 07:55 PM
ol' grouch's Avatar
ol' grouch
The basic engine is the same regardless. There are some caveats though! On the transmission, 4X4 has a transfer case in place of the tail shaft. I suppose you could use the transfer case and not have a front drive shaft. It might be handy to have high and low range in 2wd. As to the engine, I've run into trouble with the oil pan. I got a Plymouth Trailduster once that had an engine noise. The engine had a center sump oil pan that had been beat in with a hammer. I replaced it with a rear sump pan and oil pickup.
Old Apr 22, 2025 | 12:36 AM
Kyvan's Avatar
Kyvan
I have a repair manual for 1st Gen Durangos. Do you think that would help me figure out what parts go where and what would work if I need to change it? Ironically, I needed to replace the Transfer Case on mine because it was causing Death Wobble issues.
Old Apr 22, 2025 | 01:25 PM
ol' grouch's Avatar
ol' grouch
I don't do much suspension work but I don't think I've ever seen the transfer case cause death wobble. That's usually worn or misaligned steering components.
Old Apr 22, 2025 | 02:12 PM
As said, T-case won't cause that. That loose steering parts. DW also isn't really that common on independent suspension trucks.......
Old May 10, 2025 | 09:02 PM
Kyvan's Avatar
Kyvan
The suspension is the weakest part of the vehicle, outside of the rust issue. It began stalling a couple of weeks ago, and I took it in. Something about a part connected to the distributor cap, so both were replaced. Hasn't stalled yet. Thank you for the help and advice.
And thanks to HeyYou as well.
