Lights flashing on and off....
Old May 4, 2004 | 08:17 PM
whirlyblades's Avatar
whirlyblades
Default Lights flashing on and off....
Hello all!!!
Sunday night we had a heavy rainfall. After it was over, I got into my 2001 Durango and began to drive. After a few minutes, the head lights and dash lights began flashing on and off. I was hearing a clicking with every flash of on and off. When I got home, the remote would not lock the doors. Neither would the electric locks inside the truck. When the door was open the dome light would also flash.
Monday morning when I got in the truck, all was well. Was this just caused by moisture or should I be concerned?
Any advise would be appreciated.
Thansk!
Old Jan 31, 2008 | 08:31 PM
spectorcr's Avatar
spectorcr
Default RE: Lights flashing on and off....
I Know you posted this ages ago did you ever get an answer Im having the same problem
Old Feb 2, 2008 | 01:36 PM
kiddurango's Avatar
kiddurango
Im having the same problem. My twist is that the heater will turn off if my headlight are on, but when I turn the head lights off it begins to work normal. I hear the clicking sound and my fuse box by the driverside door of my 98 durango really begins to click.
If any one has any idea what is wrong a response will be apprciated.
Thanks.
PS I will probably go to the dealership in a month to check it out. When I do I will make sure I post the results.
