Engine control module
Old Feb 7, 2006 | 03:17 PM
cbreeze191's Avatar
cbreeze191
Default Engine control module
Hey,
I just bought a '03 Durango RT. I'm looking to see if my Mopar Performance PCM out of my '99 Durango wiil work in my new RT. Both are the 5.9 engines however looking online and in the '05 Performance catalog the latest 5.9 engine controller I can find states it's for '99. Wondering if anyone has any information on whether or not it will work.
The part # for the controller is P05007111.
Any information would be useful Thanks
Old Feb 14, 2006 | 02:10 AM
1 bad durango's Avatar
1 bad durango
Default RE: Engine control module
sorry man you cant use a 99 controler on the 03 ,,if you are looking for computer upgrade go to krcperformance .com and get a custom flash which means : your rev limiter moved to 6500 rpm ,speed limiter moved from 118-140 mph,shift point can change and pull or add timing,,,cost about $350-400 its worth it when u start to add high performance parts
