universal garage door opener
Old Feb 17, 2006 | 09:51 PM
joer6's Avatar
joer6
Default universal garage door opener
i just purchased a 2003 durango, and i am having trouble programing the universal garage door opener to work with my electric garage door mechanism. the brand name of my electric door opener is electrlift and it looks old. this is my first post and hope to have many more of good things. any help would be great. i was just wondering if the owner manual was leaving anything out that anybody else has tried. thanks
Old Feb 19, 2006 | 03:07 AM
Last Of The R/Ts's Avatar
Last Of The R/Ts
Default RE: universal garage door opener
If I remember correctly, you hold the two outer buttons until the light blinks. Then you hold the button of your choice and press the garage door opener so that it can catch the code. You have to make sure the garage door opener does not use the "rolling code" sequence. Basically this is a technique that most garage door openers use so that someone could not do exactly what you are trying to do, scan and catch the frequency for your opener.
Old May 4, 2006 | 12:51 AM
columbusgeek's Avatar
columbusgeek
Old post I know.
It is useful to know that it takes 20 seconds of pressing the outside buttons for it to reset. Its not required that to do this step either.
When you go to step 2, you will see the indicator light flash faster when the code is properly learned. Then you can release the buttons and bask in the glow of how clever you are....
...or pass out and die because you left your truck running and the carbon monoxide is about to kill you.
