2000 Durango engine swap 4.7 to 5.2
Old Mar 23, 2006 | 12:31 AM
rolstan2's Avatar
rolstan2
Default 2000 Durango engine swap 4.7 to 5.2
Hello folks, My mother in law has a 2000 durango with a blown 4.7 engine on an auto trans. will a 5.2L fit in it on that same trans? And all the computer stuff work? Thanks
Old Mar 23, 2006 | 01:46 PM
89Daytona's Avatar
89Daytona
Default RE: 2000 Durango engine swap 4.7 to 5.2
The 4.7L uses a different transmission than the 5.2L
http://www.allpar.com/model/durango-2004.html
http://www.allpar.com/model/durango-...owertrain.html
http://www.allpar.com/mopar/47.html
http://www.allpar.com/mopar/318.html
The engines also have a bunch of electrical differences, I doubt you would be able to use the same electronics on the 5.2 as on the 4.7L.
You would probably be better off pulling the engine out and reabuilding (depending on what killed the engine) it then putting it back in. Or you might be able to get a 4.7 from a junkyard fairly cheap seeing as the engine has been around since 1999.
Old Mar 24, 2006 | 12:21 AM
rolstan2's Avatar
rolstan2
Thanks for the info, was hoping it would give us more options. But oh well, 4.7 it is then. Thanks again
Old Mar 26, 2006 | 09:56 PM
hydrashocker's Avatar
hydrashocker
Definitely rebuild the same motor or different 4.7L. You are talking about throwing allot of money into it for not much power ratio.
