Removing Fan/Clutch
You should already have an electric fan on it as an auxiliary for when the A/c is on.
If you need more cooling or are looking to gain a little hp, they make dual setups that you can buy.
They do make electric fans. Are you just looking for a power mod, or just run it in a hot environment? If you replace the clutch fan, replace it with one that is the same size or a small bit larger than the original fan or it wont work properly.
