Front Axle Pinion Seal Replacement
Old Apr 8, 2006 | 03:51 PM
ozzie1957's Avatar
ozzie1957
Default Front Axle Pinion Seal Replacement
Hi Folks,
Does anyone know/have the procedure to replace the front axle pinion seal on a 4X4?
If so can you post it?
And if you have done this can you post your experience?
Thanks,
Ozzie
Old Apr 9, 2006 | 09:22 PM
hydrashocker's Avatar
hydrashocker
Default RE: Front Axle Pinion Seal Replacement
Never gone that far into the axle. But you should go pick you up a Chilton's manual from the auto parts store before you even start that kind of a job.
