Blowin Fuses
Old Apr 17, 2006 | 07:46 PM
carbophat's Avatar
carbophat
Default Blowin Fuses
I have a 2003 Durango that keeps blowing the 20A fuses in the box. The fuse is for the 12V power outlets..
Old Apr 18, 2006 | 01:11 PM
Digitoxin's Avatar
Digitoxin
Default RE: Blowin Fuses
Are you using any of those power outlets to run a accessory? A lot of times it is the accessory causing it to blow.
If you have several outlets, unplug one at a time and check if the fuse blows again. You may have a outlet shorting also.
Hope this can help. Let me know.......
Old Apr 18, 2006 | 02:22 PM
carbophat's Avatar
carbophat
I use only One of the outlets, which Is for a cellphone charger.. other than that, i don't use the others but on vacation trips (2x's a yr) for the DVD player..
Old Apr 18, 2006 | 07:11 PM
Digitoxin's Avatar
Digitoxin
I have seen a lot of cell phone chargers blow the fuse. It is caused by poor contact in the outlet socket. I have cleaned them out and bent the tabs on the charger connector to help get a good contact.
Old Apr 18, 2006 | 08:11 PM
carbophat's Avatar
carbophat
Thanks bro, I will have to check that out and see if that is the problem..
Old Apr 28, 2006 | 12:43 AM
carbophat's Avatar
carbophat
I tried the the ph charger and it didnt work.. anymore ideas?
Old May 15, 2006 | 03:55 PM
carbophat's Avatar
carbophat
Can Anyone help ME???
