New MSD Ignition
Old May 2, 2006 | 12:52 PM
hydrashocker's Avatar
hydrashocker
Default New MSD Ignition
Well got another fun toy for my D to put under my belt. Thats right MSD Ignition!
I got most of my parts from MSD but had to buy a couple of parts from Accel to make it fit.
Oh well! It runs like a champ. If anyone needs the part numbers I got em.
Old May 4, 2006 | 03:21 AM
99DurangoSLT's Avatar
99DurangoSLT
Default RE: New MSD Ignition
hey! tell us wich parts u got, and how much $ ... and... How it works...
a friend has all the ignition upgrade on a 4.0 XJ and let me say THAT BEAST IS ALIVE.
Ceasar
Old May 8, 2006 | 01:35 AM
1 bad durango's Avatar
1 bad durango
which coil did you use ?????????
Old May 9, 2006 | 02:54 AM
hydrashocker
I posted this already, but here it is again.
MSD 8.5mm Wires #32189
MSD Blaster Coil #8228
Accel Distributor Cap #120329
Accel Distributor Rotor #130328
Accel OEM Adapter to Coil #14002AH
I had to use some Accel parts because MSD and Mallory don't make them yet.
The truck starts and runs like a champ! Im going to try to gap the Champion Truck Plugs .005 more to handle the new spark without fouling. I will post the results later. These are OEM replacement parts and will bolt up to OEM perfectly.
Old May 16, 2006 | 01:42 AM
1 bad durango
when you get tired of that blaster coil get a hvc2 coil by msd way hotter than the blaster,better when you start to build some serious hp
Old May 19, 2006 | 03:48 AM
henry75's Avatar
henry75
got the part number on the hvc2 coil??
Old May 19, 2006 | 11:58 PM
hydrashocker
ORIGINAL: 1 bad durango
Dude!
When I get the super charger and some more upgrades to (warrant buying that) or a more upgraded system than that, I'm sure that wont be a problem. The other site members (at least a lot of them) don't have a 500+Hp motor's. Not to mention that this coil I bought isn't even in the MSD computer yet. I had to call a rep and ask them to run a search under a full sized truck to match it up with what us 5.9L D's got.
Like I said it is OEM replacement not full out 500+ Hp only.
Do you have the part number for this coil, or do they even make it yet? Also what part #'s do we need and equiptment, to install that coil into our trucks?
Old May 23, 2006 | 02:19 AM
1 bad durango
the part number is 121-8253 out of jegs high performance ,you must have a c/d type ignition box or it wont do you any good ,but once you have it you will love it i had to make a small mounting plate for the coil,oh yea make sure your plug wires are in good shape and at least 8mm somthing with low resistance,,,coil coat about $119
Old May 23, 2006 | 09:57 PM
hydrashocker
What part # and maker, is the c/d type ignition box do we need to run it?
Old May 24, 2006 | 01:31 AM
1 bad durango
sorry would help if i gave you all the info ,,it a mallory digital box hyfire vi al ,built in rev limiter #650-6853m $170 through jegs
