Vibration under acceleration
Old May 18, 2006 | 11:20 AM
Blue600's Avatar
Blue600
Default Vibration under acceleration
Under acceleration or load I have a vibration that I can feel through the steering wheel. Let off the accelerator and it goes away. It feels like a tire out of balance but it's not the tires. Maybe u-joints in the front driveshaft or a CV joint? Any ideas appreciated. This is a 2000 Durango 5.9 AWD with 113,000 miles on it.
Old May 18, 2006 | 11:52 AM
Kensai's Avatar
Kensai
Default RE: Vibration under acceleration
Seems like you are on the right track. That would be my first guess as well.
Old May 18, 2006 | 11:48 PM
Blue600's Avatar
Blue600
It's my wife's car and when she got home tonight I drove it again. The transfercase shifter vibrates at the same speed as you can feel through the steering wheel so I'm thinking it's in the front driveshaft. Like I said before letting off the throttle, the vibrations go away.
Old May 19, 2006 | 03:24 AM
kjun's Avatar
kjun
Sounds like a U-joint.
Old May 20, 2006 | 06:14 AM
28this's Avatar
28this
Check the front drive shaft.
Old May 21, 2006 | 12:31 PM
Blue600's Avatar
Blue600
I jacked it up yesterday and I can't find any slop anywhere in the front drivetrain. Everything is tight [sm=bangbang.gif]
Old May 21, 2006 | 01:21 PM
28this's Avatar
28this
Did you check the rear drive line also? If it is good and you found nothing under the front, I would start looking at brakes rotors.
Old May 21, 2006 | 05:23 PM
Blue600's Avatar
Blue600
I'm pretty sure it is not the rear shaft. The steering wheel vibrates and it only does this accelerating, let off the throttle and it goes away. It does this from 20 -60mph with 50mph being the worst.
Old May 21, 2006 | 11:49 PM
28this's Avatar
28this
If its not the tires, it has to be in the drivelinne somewhere. Universal or slip yoke.
Old May 23, 2006 | 11:14 AM
Blue600's Avatar
Blue600
Well it was the u-joints on the rear driveshaft[] It was transfering the vibrations through the t-case to the front end.
