Engine wont start
Old Jun 29, 2006 | 07:26 PM
pabloaviles's Avatar
pabloaviles
Default Engine wont start
I have a 99 durango 5.2 Every morning when i try to start the engine it wont start, it seems likes it´s flooded, i don´t know what the ploblem is. Help please
Old Jun 29, 2006 | 07:46 PM
Mean Green's Avatar
Mean Green
Default RE: Engine wont start
Make sure your battery is grounded well and that the posts and clamps are clean. I had the same problem when my negative cable was a little loose. Also have you changed the plugs recently because you should only use champions I found out about that the hard way as well when I had to warm up my truck without letting off the gas to keep it running.
