just replaced the evap and air was working fine today i adjusted the cold to warm for 2 minutes and it never got cold again when i put it on max air it blows hot air same as the rear ac please help thx
also saw some water under the truck a couple of days ago but its not runing hot and the front evap cost me about 7oo dollars is there an ac belt i can check or compressor i can check is this a dealer issue
I would suggest getting the 134 that has dye in it and get a black light charge the system at night or in a dark garage and run the ac to see if there is a leak. It sounds like it may be a big leak with how fast it went out on you.
*EDIT* Water is normal when you run the ac.
i just checked the ac it has freon in it still but looks like an electric problem came up with some elec codes for the trans any chance this can be my pcm not working
