Durango Blower Switch
#81
I unscrewed the harness on my 2001 and besides the oxidation of the melted wire in the picture, everything including the resistor looked alright for its age. My dealer wants to charge me $75 for a resistor so I put it back together and everything worked for a little while again but it just stopped. Could it be the melted wire going to the harness that is causing a short? What would be involved to replace the harness and the bit of wire that has melted?
Mike
Mike
#84
#86
Get the new pigtail from the dealership its updated from the older one with thicker guage wires and better connectors.my first time i lost only high and that was the problem, then i lost all low speeds and replaced my resestor with a factory one and have had not a problem since. first resestor was from carquest and more expensive than the dealer for once.
#87
#89
#90
Easiest way in my humble opinion is to remove and replaec the harness from a salvage yard donor. As long as you are not color blind you should be able to splice with fairly basic tools and supplies available at your local auto parts store. Here are a few key points to remember though.
1. Take a photo of the harness in your vehicle to bring to the salvage yard. Make sure the colors match for the wires. They should match but doesn't hurt to have modern technology at your disposal.
2. As long as the years are compatible a Dakota maybe acceptable substitute for donor harness..
3. On the donor vehicle once you have established the wire color coding.....cut the donor harness as close to the firewall as possible.
4. When you cut your bad harness cut as close to the resistor as possible.
The reason for number 3 and 4 is to leave as much wire as possible for splicing in case of a bad splice. There are only 5 wires but if you have someone good with splicing and electrical work especially in enclosed spaces you should be fine...
5. Just match the colors and ops check zip tie the left over wire.
6. Verify condition of donor harness and make sure it is in good shape.
7. Total cost should be under $50...not more than about $20 for the donor harness, and about $30 for connectors, crimping tool, electrical tape, etc...
8. If there is any power left in your current resistor...use that for troubleshooting and ops checking.... after wiring is spliced then install the dealer resistor.....No sense in ruining another brand new resistor if there is something in the wiring further down that is causing over voltage.
Good Luck!!!
Good Luck!!!
