R/T 2000 SMOKE SHOW
Old Aug 25, 2006 | 12:35 PM
stephano's Avatar
stephano
Default R/T 2000 SMOKE SHOW
Hi gang !
Can I make some smoke shows with my AWD D if I remove the front shaft ?
I have seen on a forum that it will work if I put the selector on 4 hi lock. Wil it work even if I have a LSD rear axle ????? And , will this kind of action be damageable for my D ?
stephano
Old Aug 25, 2006 | 02:17 PM
Mean Green's Avatar
Mean Green
Default RE: R/T 2000 SMOKE SHOW
well of course you could damage the tranny and I wouldn't recommend disconnecting anythiong just to burn up your tires, I'm sure that is a possibility though... The LSD will propably keep you from burning both but idk.
Old Aug 27, 2006 | 12:20 PM
hydrashocker's Avatar
hydrashocker
If your just looking for a nice pic why not just get one in the dirt, mud or rock crawling. Don't disconect your driveline in order just to get a pic. Your driveline is balanced and should be kept in the same place.
Old Aug 27, 2006 | 04:22 PM
Kensai's Avatar
Kensai
If you truly want to permanently disconnect the front shaft when you do not want to use it, you should change out the full time transfer case with a part time transfer case. That way, you can drive all you want in 2WD mode while leaving the front shaft connected.
