radio removal- 2001 durango
Old Aug 26, 2006 | 12:08 AM
dizzy d's Avatar
dizzy d
Default radio removal- 2001 durango
DOES ANYONE KNOW HOW TO REMOVE RADIO.
Old Aug 26, 2006 | 12:40 AM
Mean Green's Avatar
Mean Green
Default RE: radio removal- 2001 durango
Take the trim off that surrounds the radio. You just take a screwdriver and pry it up then pull it out gently. I believe there are 2 screws to remove that hold the radio in but I haven't actually removed the unit. Should be fairly straightforward from there though. You have the stock radio with a tape and cd player right?
Old Aug 28, 2006 | 11:38 AM
dizzy d's Avatar
dizzy d
YES , I TRIED THAT BUT IT HAS THE WOOD PANELING AND IT DOES NOT PRY OFF. IT'S LIKE FLUSHED ON AND RESALLY NO SEEMS.
Old Aug 28, 2006 | 06:36 PM
Mean Green's Avatar
Mean Green
I have the wood trim too it does come off it is plastic. I have had to pull mine off a couple times already. Just start from the bottom right hand corner and move a few inches left if you can't get under it. You might be trying in a spot that has the clips so it's tighter. Anybody that has an 01-03 that can help this guy?
